Hello friends.
 I brought a LG 43 inch 4k smart TV for my room. I'm so satisfied with the TV.   Unfortunately I gotta go out side of the country more than one year for my duty.  So is it okay to store my TV without turning on more than one year?  Will it be a big issue for the  TV components?  😎
    • By Ahmad Baeisa
    • By akhil7j
    • By Puja aingh
      Dear LG Team
    • By John Nguyen
    • By Rizwan Sumra
