IPlayer / Freeview Play
By nigelh
I have an LG43UN71006LB TV. I don't have an option to download the Freeview app. When I search for it in Content it isn't found. However I was told that the app should be available on this model. Would appreciate if anyone could confirm I this is the case and if so why it isn't available to download.
By Bella Lee
link hidden, please login to view. With Tunelf Spotibeat Music Converter, you can and then transfer them to LG webOS Smartwatch for playing without limits. -
By Gregor Huc
By Abhishek_02x
I am using the lg tv from 2 years and I found an amazing experience till now.
But I like request about Play box TV app. Please add this app in store section so that I could download it on my tv.
It would be helpful if you respond to my email. This app is very demanding now a days as it comes with the excitel broadband service.
- 103 answers
- 74,801 views
- 2 answers
- 6,854 views
- 4 answers
- 22,122 views
Anthony Place
I have a strange problem with freeview play and Iplayer on my 55 E6 I need help first is this the correct place to post
The problem started about 2 months ago
If i select a BBC program from the past by scrolling through the freeview guide Iplayer starts as usual But when it starts playing there is no picture or sound if subtitles are on you can see the the subtitles going by but no sound of picture.
if i start iplayer using the app UI to watch the same program it works fine
all other catch up works through the freeview guide
If i am watching a bbc program and press green to restart the program it works ok also
I have contacted Freeview they told me to contact BBC
I have contacted bbc iplayer help they told me to contact LG
I contacted
I am told LG said they did not see it as a problem and would do nothing
I spoke to again and was told LG tvs do not support Iplayer any more
I also have a 55uh850v that I use in my cinema as a 3d monitor this tv is olso webos3 this tv has exactly the same problem
I also have a 49UH610v this works perfectly
I also have a OLED55B7V this has the freeview guide disappearing problem that is well documented in "LG TV Freeview Play" forum but when its working the Iplayer works ok
I have 70mg fibre broad band and the tvs are on wired ethernet
I do not know what to do next
