Rita
This tv is impossible. I can't download user agreements.
Yes, My tv IS connected to web.
I tried manual update. File to large for thumb drive.
Do I need to restart from scratch?
I never had problems like this.
LG WebOStv UK 6300PUE
Thanks.
Hi Rita,
Sorry that you are having issues with your new TV, unfortunately the problem with the User Agreement form is quite common with the TV struggling to use the settings provided by our internet service provider.  If you have a look at some of the other threads on the issue you will find that setting the TV's DNS settings to those of Google's DNS server you will be able to get past your issue:
https://www.lgwebos.com/search/?q=user agreement
    • By Rita
      Should I just buy a Roku ?  I hate this TV.
      Lightning hit my Sony bravia.
      I wish I hadn't bought this thing
