Netflix Buffering Issue
 know the smart tv apps often get shit on, but I’m not sure if the C8’s app is extra buggy or I got a lemon.
After about 10-15 minutes into a show, Netflix’s buffering percentage will appear (usually at 99%) and then it errors out after a minute and I have to go back into the main menu and replay.
I’ve got a PS4 Pro and a Roku as backups that don’t have this issue, but I really wanted to use the app built into the tv. It’s currently hardwired with an Ethernet cable.
Anybody else had this issue or know of any solutions?
    • By RJ Fischer
    • By Regis Wheeler
    • By JasonB
    • By AMK
      Tv model 55UJ630V-TA
      Sw version 06.10.50
    • By jcol5786
