TV's User Guide DOA!
By Hasan Ghasabi-Oskoei
Can you help?
By Peter_T
LG Radio+ Brings LG Smart TV Users Free Listening to a Wide Range of
Popular Podcasts and Live Stations, Also Accessible From LG’s Audio Devices
SEOUL, Dec. 20, 2024 — LG Electronics (LG) has launched LG Radio+, the company’s ad-supported audio streaming service, now available on LG smart TVs running webOS 6.0 and above. This new service allows users to effortlessly access a diverse selection of podcasts and radio programs. For a streamlined user experience, LG Radio+ will work with the LG ThinQ app,1 providing users with a convenient way to access and enjoy their favorite audio content no matter where they are in the room.
To offer a curated list of audio streaming content, LG has partnered with global radio and audio provider Radioline, giving users an all-in-one audio platform allowing effortless access to news, sports, music and more. Available in the U.S. and Korea, LG smart TV users can explore a range of live stations and podcasts, with options such as NPR, CNN Radio, Fox Radio or The Joe Rogan Experience in the U.S., or popular local stations and podcasts in Korea.
The LG Radio+ app can be accessed from the Content Store or Apps or by using the voice search function of the LG Magic Remote, providing a fast and convenient way to discover new listening content.
For quick and easy exploration, LG Radio+ has an intuitive interface with a comprehensive channel list, presenting popular audio channels on the On Air page, alongside a personalized selection of favorite channels. Users can navigate the On Air and Podcast pages to access their desired audio streaming content, while the Featured page provides a dynamic view of trending music, updated in real-time to highlight the most popular or season hits. This enables users to search, discover and enjoy their preferred audio content with ease out of a large library of over 14,500 channels in the U.S. and over 440 available in Korea.
As part of LG’s commitment to enhancing user convenience and connectivity across the company’s life-enriching products, listeners will be able to access LG Radio+ through the LG ThinQ app,2 enabling enjoyable audio streaming on LG audio devices with minimal effort. What’s more, LG Radio+ will also be available to access through the My button on xboom speakers in 2025.
LG continues to elevate the user experience with a broad range of content and an intuitive user interface, making it effortless to explore and enjoy audio entertainment. To learn more about how LG is enhancing the audio experience, visit
1 Available at a later date in 2025.
2 Accessible via xboom category
By pivotCE
3. Soldering iron and solder
2. Items 2-4 above
1.
2.
Prepare the Wires
Final Thoughts
#webos4ever
By Muser
James M DeLuca
My brand new 75UK6190PUB TV's USER GUIDE seems to have no response once reaching its home page.
I press HOME on the remote . Then select the USER GUIDE app from the bottom of the screen. The home page of the USER GUIDE displays full screen with NONE of the topics highlighted. All attempts to progress in the guide fail including the arrow keys. The only remote button button that works is EXIT (and POWER of course).
Using the USER GUIDE on a Chromebook from the LG website seems to work fine.
I have NOT attempted to upgrade the firmware yet, allowing for the possibility that I am doing an incorrect action.
I forgot to gather my product's S/N & current firmware version when composing this message on my desktop PC, but will provide them upon request. I do not yet have a keyboard and mouse connected to the TV yet, and am using other devices to use this forum.
