  • 1
USB Always On Option
Is there an option somewhere to turn the USB ports to always be powered on? I two LG TVs and have a Chrome Cast and a Fire TV plugged in that I would like to remain on even when the TV is off. Looked around the menus and could not find. Thanks
7 answers to this question
Ease of power cords and cleanliness of wires. The USB ports are right there and unless I were to attach a thumb drive, I am not sure what purpose they serve besides offering power.
  • Like 2
Ever find a solution to this? I would really like to have this option as well
On 1/17/2019 at 7:18 AM, nemilose said:
Why don't you use an external power adaptet?
thanks for the idea!  I, too, was looking for cord management and this idea never occurred to me.  I busted out the USB extension & power adaptor I sure was going straight to the landfill and problem solved: we dont have to wait for the Roku to boot & probably what was more concerning was the TV freaks out while the Roku boots (flashes black multiple times) & once crashed the display driver to the point of being all green with lots of vertical black lines - unplugging the TV was the only way to reboot it.  needless to say, on a 1d old TV, not very comforting - now we dont have to worry about this failure vector!
and, for the record, it would be great if WebOS had a s/w switch to enable USB ports to always be powered.
How can LG TV's power up in USB mode and auto play the file? We are using some TV's as displays in museum with USB drives attached with files. Would like when TV powers on in due to IR signal to start up by playing file. Anybody help
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By duckie133
      VERY ANNOYING!!!!!!!!!!
    • By Cash
      Have LG OLED 55B36LB bought in 2023 in UK.
      Trying to change area option from 3122 (EU-UK) to 4816 (AJ-India) using a service remote.
      It does not update or change.
      any help for guidance will appreciated.
    • By whaleandtuna
      Please Help. I have LG qned tv with webOS 23
      1) What I did: with svc remote -> in start -> 0413 and all, area option was changed.
      I was trying many numbers to find the code for KR (which didn't work).
      2) What I wanted : change area option from CA -> KR (widely known area codes do not work)
      Original code: CAD 22411
      3) Problem: Once I put a number between 19461 ~ 19489, Language&Country is set to EU and would not change the country with the other numbers.
      Area option: 19461 ~ 19489 Continent index: 5 ~ 33 Language & Country: EU
      Now I put 22411 to change it back to original region, but the country would not change from EU to CA, the area option is back to 19461.
      If anyone is trying the area option numbers, don't put any number between them.
      If any one knows how to resolve, please help me to escape from EU.. I am so desperate.
      FYI just in case
      hk 17930
      hk 17935
      co 17560
      ph 15670
      cn 17816
      ja 17211
      aj 17083
      tw 17432
      pa 17679
      hn 18618
      ca 18362
      mx 18456
      hn 18584
      br 18789
      cl 18876
      pe 19033
      ar 19123
      ec 19251
      jp 19345
    • By Satya_
      Software version 05.30.10 default web browser just updated and the address bar appear on the top of the screen which bother me a lot while playing a video please add a Full screen option to it
