Firmware vs. Software
By OliverRC
By SHawk
By Sqwazy
By majorusa
- 3.23.24 - Romania- 47LB730v
By Low Grade
i was prompted to update the tv software.............lucky thing that i turned off automatic updates couple days beforehand...............the update will be over 1 GB but the free space on the tv internal storage is less than 1 GB ............🤣
so any harm if i DON'T update the tv software from now on.......?🤔
i will update Youtube app though...........
AmrDesign87
Hello... I have a question about the difference between the firmware which is upgradeable and now it is 5.30.15 and the WEBOS software version 3.3.3-4403 (dreadlocks-dharug) which is not upgradeable.... And why it is not?
