Data Cap and Stream Quality
Ive lived in a city my whole life, and just moved to a rural area that has 6x more expensive internet that is 4x slower and has low 50gb monthly data cap... thanks VIASAT AND HUGHES NET!
Anyway, I think i may get me a lg uk6200, mainly cause low input lag, and hopefully I THINK its the 6300 without the stupid slimAI, and bluetooth features... hopefully..
I ask, with the amazon, netflix, hulu app, and youtube app, Can i set the data rate to SD or lower. I simply cannot use 720 or 1080, or by god 4k or i will hit my cap limit in probably a few days. or hours lol.
I used to love my palm pixi and hopefully the webos evolved a bit to accomodate the world that has data caps. It would be nice to hear someone who knows the question... otherwise I will probably have to buy a roku for that functionality
Out of mentioned app I use only YouTube. I couldn't find an option to change the stream quality within the application. It automatically adapts to the available bandwidth. I may change the quality if I limit the TV's bandwidth within my router. I don't know whether your router has such a capability, but you may try something similar.
      Key Specifications:
      Powered by the α8 AI Processor, LG’s Latest QNED TVs Elevate the Home
      Entertainment Experience With Lifelike Picture Quality on Ultra-Large Screens
      SEOUL, Dec. 28, 2023 — LG Electronics (LG) announced the newest lineup of 2024 QNED and QNED Mini LED TVs, offering a wider selection of screen choices including ultra-large 98-inch with vibrant picture quality, advanced AI-powered processing technologies, extensive personalization features and sophisticated design.
      Evolving further, LG 2024 QNED TVs have developed significantly more intelligence with the α8 AI Processor, improving upon its predecessor with a 1.3-fold increase in AI performance, a 2.3-fold enhancement in graphic performance and a processing speed that is 1.6 times faster.
      Leveraging cutting-edge technology for a more refined visual representation, AI Picture Pro offers the ultimate picture quality based on deep learning. This versatile feature adeptly distinguishes faces, objects and backgrounds within a scene, enriching the texture and fine details to present images with unparalleled realism. Dynamic Tone Mapping Pro splits the picture into blocks and analyzes each in real-time to detect the darkest and brightest areas, elevating the details with precise HDR optimization to deliver three-dimensional image quality. With Personalized Picture Wizard, users can effortlessly customize the image quality by simply selecting a few preferred images from a given selection that are intelligently set up through deep learning.
      In addition to vibrant picture quality, AI Sound Pro captivates viewers with the audio excellence of virtual 9.1.2 surround sound from the TVs’ built-in speakers. For a unified audio system, WOW Orchestra seamlessly integrates the LG Sound Bar and the TV’s speakers, resulting in a mesmerizing 3D sound experience.
      Featuring LG’s Quantum Dot and NanoCell color technologies, the company’s latest QNED TVs deliver crisp and vivid picture quality for hyper-realistic viewing. With enhanced color reproduction, the authentic colors of QNED TVs heighten the visual depth for a more immersive and three-dimensional home entertainment experience.
      Achieving realistic contrast, LG QNED Mini LED TVs utilize Precision Dimming technology to improve gradations and accurate backlight control, and LG QNED TVs feature local dimming technology for vivid contrast and exceptional brightness.
      The LG QNED Mini LED TV QNED90 model features Million Grey Scale that differentiates between shades of gray and represents gradation with a 20-bit accuracy, providing immensely vibrant contrast.
      Boasting a sleek and sophisticated design with a slim profile of only 29mm, LG 2024 QNED TVs, including the QNED85 and QNED80 models, blend into any space and add a premium touch to the household. The TVs can also be mounted on the wall, providing greater flexibility for furniture and appliance arrangement.
      LG 2024 QNED TVs also elevate the home entertainment experience with versatile personalization and increased convenience. With the webOS Re:New program,* LG is offering an upgrade to the latest version of its webOS smart TV platform to give more smart TV owners the most up-to-date user experience for the next five years. This notable offer comes to LG QNED Mini LED 8K models launched in 2022 (QNED99 and QNED95 series) and will be extended to additional models in the QNED TV lineup worldwide in the future.
      By utilizing the latest LG webOS smart TV platform, users can create individual profiles to tailor the experience to their preferences. The TVs can differentiate between voices based on the user profiles and offer personalized recommendations by interpreting patterns from their comprehensive usage history.
      Furthermore, the main home UI screen of the newest version of webOS features Dynamic Q Card for fast, effortless access to its services, with customized organization into groups, such as Home Office, Home Hub, Sports and Games. To enjoy users’ favorite digital media, LG 2024 QNED TVs also support Apple AirPlay and Chromecast for enhanced convenience in connectivity and compatibility with mobile devices.
      Enhancing the user experience for individuals with diverse abilities, LG 2024 QNED TVs supplies an array of accessibility features including dedicated menu settings, sign language avatars, remote control tutorials, and guides for quick problem resolution.
      LG’s 2024 QNED TV lineup caters to customers’ diverse needs and preferences with a broad range of screen sizes, led by the ultra-large 98-inch blockbuster, a truly massive screen that will fully immerse viewers with its magnitude. The addition of the giant 98-inch model addresses the growing demand for larger TVs in the premium LCD TV market, and the extensive lineup also provides customers with multiple alternatives that will ideally suit any space, including 43, 50, 55, 65, 75 and 86-inch screens.
      “The LG 2024 LG QNED TV lineup takes the viewing experience to a whole new level with an advanced processor that enables outstanding audio-visual experiences across various screen sizes, while also providing a personalized user experience tailored to each individual’s unique lifestyle and preferences,” said Baik Seon-pill, head of the LG Home Entertainment Company’s Product Planning Division. “We remain committed to delivering an unparalleled customer experience, drawing upon our decade-long expertise with webOS.”
      CES 2024 visitors will have the opportunity to explore LG’s most recent innovations and technologies in home entertainment experiences at the company’s booth (#16008, Las Vegas Convention Center) from January 9-12. To keep up with all of LG’s exciting announcements at CES by following #LGCES2024 on social media.
      * Pop-up notifications offering a full upgrade without the need to select specific UX, UI or features are only sent to customers who have agreed to receive them. Please note that this upgrade does not cover the TV’s hardware performance, features or durability.
      LG is partnering with world-renowned Danish luxury audio company Bang & Olufsen to redefine home cinema.
      link hidden, please login to view, the groundbreaking Micro LED display, and Bang & Olufsen’s flagship speakers combine to present immersive viewing experiences with ultra-large and incredibly lifelike images and powerful, nuanced sound.
      With a sleek, modern design and vivid, ultra-sharp Micro LED picture quality, LG MAGNIT delivers the ultimate in viewing pleasure. Its 136-inch, 4K UHD (3840 x 2160), 120Hz-refresh-rate screen is great for watching movies, TV shows and sporting events – and for admiring artworks – in the privacy of one’s home. By combining the performance of Micro LED with convenient features that enhance content enjoyment, LG has created a unique display for those who demand the very best.
      While the quality and size of images shown on LG MAGNIT are sure to captivate, so too will the display’s elegant, minimalist design. LG’s Micro LED solution for the home has a bezel-less screen for immersive viewing experience, and has a sturdy, stylish aluminum frame with a brushed metal finish that complements any interior décor or color scheme. Likewise, the Media Box, which serves as a controller for LG MAGNIT and shares the display’s luxurious yet understated aesthetic, harmonizes beautifully with the surrounding environment.
      Having produced such a superlative screen, LG tasked itself with finding a sound partner capable of providing an audio solution that could match MAGNIT in terms of design beauty and outstanding performance. Bang & Olufsen – beloved by audiophiles since 1925 – immediately understood LG’s vision for elevating the home cinema experience, and knew exactly which of its superior sound solutions would best complement LG MAGNIT: the distinctive, dynamic Beolab 90.
      Bundled with LG MAGNIT, Bang & Olufsen’s Beolab 90 speakers are the ideal match for LG’s Micro LED innovation in both style and performance. An aesthetic and acoustic masterpiece, Beolab 90 boasts an iconic design featuring curved wooden bases, a series of angular facets covered in sleek fabric, and finishing touches of brushed aluminum. The stunning Beolab 90 sits at the top of Bang & Olufsen’s range of Beolab speakers, all of which are compatible with LG MAGNIT.
      Beolab 90 is a floor-standing speaker that adapts output to the space it is in and the type of audio it is reproducing. With 8,200 watts per speaker, 18 premium drivers, 14 channels of 300-watt ICE power amplifiers and 4 channels of 1,000-watt Class D Heliox amplifiers, Bang & Olufsen’s Beolab 90 makes music and soundtracks come to life in a way that few speakers can.
      Dedicated to delivering outstanding home cinema and user experiences, LG and Bang & Olufsen conducted several rounds of testing to ensure seamless compatibility between the webOS platform installed on LG MAGNIT, and Bang & Olufsen’s software application. Thanks to these efforts, users can now enjoy the convenience of being able to control both LG MAGNIT and Beolab 90 via Bang & Olufsen’s remote controller.
      The LG MAGNIT with Bang & Olufsen’s Beolab 90 speakers is currently on display at international locations. Visitors can experience this pairing at the LG Business Innovation Center in Dubai, UAE, as well as at the Bang & Olufsen store in Riyadh, Saudi Arabia. Moreover, this exceptional combination will also be presented in the Bang & Olufsen showroom in Costa Mesa, California, USA, which is scheduled in September.
      A company that understands there’s no place like home, LG is trying to make home life even better through expanding the customer experience offered by its advanced appliances.
      LG presents consumers with a diverse range of products spanning around 20 different product categories, including home appliances, TVs, information technology and signage solutions. Right now, there are almost 200 million LG smart home appliances delivering customized convenience to people all over the globe. Via its rich ecosystem of products, and with the consent of its customers, the company is actively collecting and organizing data throughout the entire customer journey. Based on the analysis of this data, LG is developing various services and features to further improve the customer experience.
      By utilizing ‘big data,’ the company is showing how digital transformation (DX) can simultaneously enhance business competitiveness and bring greater value to consumers. LG is applying DX technology to several key areas of its operations, such as product development, manufacturing and sales; improving the way the company works while also creating first, unique and new – or F.U.N. – customer experiences.
      Let’s take a look at some of the innovative ‘DX-powered’ services that LG is able to provide its customers.
      Proactive Customer Care
      Inconvenient and rare though it may be, sometimes, home appliances don’t function as intended. To help avoid any major breakdowns, and the hassle that invariably comes along with them, LG developed a technology that preemptively checks for any potential issues and takes action in advance if any is required. The collection and analysis of home appliance data makes it possible to identify if a product has been incorrectly installed or is being improperly used, flagging the problem before any actual damage is done.
      LG is expanding this preventive maintenance technology, which is being used throughout its home appliance lineups, by incorporating data-based AI care services. One such service enables the company’s washing machines to notify users when the drum needs cleaning due to laundry contamination or inform them if there is a risk of pipes freezing or bursting due to cold ambient temperatures. Active rather than passive, LG’s AI customer care features can be easily managed using the LG ThinQ app.
      Upgradable Home Appliances
      LG’s paradigm-altering ThinQ UP home appliances can adapt to the unique and changing lifestyles of each customer thanks to their impressive upgradability. A first for the home appliance industry, ThinQ UP technology, which allows customers to choose which additional features or functions they download and install, was no small task to develop.
      In addition to providing a more tailored experience to users, ThinQ UP has helped LG to lower the total cost of developing and testing new functions for its appliances. In the future, ThinQ UP functions will be continuously improved based on customer usage data.
      In order to deliver innovations like ThinQ UP, it is essential to first gain a deep understanding of how customers live. LG achieves this through analyzing product usage data and a variety of ‘external’ user data, such as whether the user is sensitive to heat, how much water they drink, and whether or not they have pets.
      Customer Index
      Developed and managed by LG, the Customer Index provides a wealth of data that the company is leveraging to make its smart home appliances – and related services – even smarter. The Index is helping to extend and enhance the user experience by revealing underlying usage patterns as well as customers’ hidden wants and needs – which LG then addresses by crafting clever, new services linked to its products.
      In the future, owners of LG Objet Collection products who are interested in interior design will be able to use the company’s interior platform to find décor inspiration and purchase interior accessories that match with the aesthetic of their home appliances. As another example of what could soon be possible, LG’s Styler, washing machine and dryers may be able to connect users with specialist mobile laundry services aligned with their specific needs uncovered through the analysis of usage data.
      By seamlessly combining products, data and services into a unified whole, LG will create continuous customer experience innovation that delivers unprecedented value and convenience. And through its commitment to implementing DX technologies, the company will keep on growing and refining its ability to help consumers everywhere enjoy healthier, happier lives.
      Stay tuned to
      link hidden, please login to view for the next episode in the Future Tech series. # # #
      The Company’s First Diagnostic Monitor With IPS Black Technology,
      Features an 8-Megapixel Resolution and a 2,000:1 Contrast Ratio
      SEOUL, May 30, 2023 — LG Electronics (LG) has launched its 31.5-inch IPS Black diagnostic monitor (model 32HQ713D). The company’s first medical monitor to employ IPS Black technology, the new model provides sharp, clear images with vibrant colors and a 2,000:1 contrast ratio. LG’s new diagnostic monitor delivers consistent image quality via automatic self-calibration and ease-of-use with 6 convenient hotkeys.
      Thanks to an 8-megapixel resolution (3,840 x 2,160 pixels), LG’s IPS Black diagnostic monitor offers the level of clarity needed for medical imaging, including x-rays, mammograms and CT scans. With Multi-Resolution Mode (8, 6 and 4MP), users can adjust screen resolution to suit the type of image being viewed.
      Equipped with IPS Black technology, the 32HQ713D provides clear image definition with deep blacks and detailed expression in the low gray tones. LG’s diagnostic monitor also features a built-in front calibration sensor that enables automatic self-calibration to help keep image quality stable.
      Additionally, the 32HQ713D comes with Focus View Mode and Pathology Mode. Controllable with either mouse or keyboard, Focus View Mode makes it possible to select a specific part of an image to review – dimming the rest of the screen to help highlight the area of concern. Pathology Mode provides image clarity and accuracy as if looking at a microscope.
      LG’s new diagnostic monitor offers a convenient user experience with 6 hotkeys that make it quick and simple to adjust various settings, including mode, screen resolution and lighting. For convenient management, the Presence Sensor automatically turns the display off after 5 minutes if no motion has been detected. The monitor also comes with a one-click stand that simplifies the installation process and offers ergonomic comfort with adjustable tilt, height and swivel.
      “LG’s new diagnostic monitor offers the high contrast needed for displaying clear medical imaging,” said Silas Choi, vice president and head of the B2B solution business division of LG Electronics Business Solutions Company. “Leveraging our outstanding display technology, we will continue to provide medical monitors that meet the specific needs of medical professionals.”
      The 32HQ713D is now available worldwide. For more information about LG’s diagnostic monitors, visit
      link hidden, please login to view. Key Specifications:
      LG Diagnostic Monitor (32HQ713D)
      Panel Panel Type IPS Black Inch 31.5-inch Aspect Ratio 16:9 Resolution 8MP (3840 x 2160) Color Gamut (Typ.) sRGB (CIE 1931) 100 % Brightness (Typ.) 1000cd/m² Contrast Ratio (Typ.) 2000:1 Response Time (Gray-To-Gray)
      14ms (GtG, Overdrive Not Supported) Feature DICOM Compliant Yes Hardware Calibration Yes (Software Application: LG PerfectLum)
      Display Mode Multi-resolution Mode (8/6/4MP), Focus View Mode, Light Box Mode, Pathology Mode Video Signals Input Terminals DisplayPort x2 User
      Convenience PBP / Dual Controller Yes (2 PBP) / Yes Lighting Yes Hot Key Yes (6 keys) Presence Sensor Yes Physical Specifications
      Adjustable Stand Swivel: ±15° / Tilt.: -5°~15° / Height Range: 110mm * Product specifications may vary by region and are subject to change without notice.
