4 answers to this question
Hi fjunk19,
The simple answer is that you cannot install Flash as Adobe dropped support for mobile and Smart TV platforms back in 2011, and is killing off the product at the end of 2020.
So if you are visiting a site that is heavily dependant on Flash you are going to be out of luck on any mobile or Smart TV that does not run Android.
Joint Fires Working Group and W = what's G = good W = with Y = you AKA wasgoodwitchu; often used to express confusion
or it could mean : testing testing
