Virtual keyboard disappear after 2 minutes afk
By Roy Brown
By atcronin
By mean2
By PVD
By JRay
- 0 replies
- 2,626 views
lg smarttv Usb
By Trouble125,
- 1,834 views
- 0 replies
- 4,865 views
- 10,592 views
Long Lý Đức
I have an issue when working with LG WebOS LK5700PTA, when i focus into an input field that use LG default keyboard, if i afk for 2 minutes then keyboard will auto disappear and i cant make it display again, i had to focus out then refocus into input field to make keyboard display again. I use Enact as framework to built my app. Had anyone catch this issue before? How to prevent keyboard disappear or make it display again when i press button " ok" on input field?
