A lot of us have had this problem since the last update and nothing you do changes it. If your modem or router is nearby then hookup with an Ethernet cable and that will work fine. I use a Fire stick and that works fine. I tried some temporary fixes but it’s not worth it. A moderator said techs are working on an update to fix the problem. If you are getting the annoying message on the screen you can go to store mode. We just have to be patient in the meantime. Not much else we can do. If I hear anything I will pass the information on.
  • 1 year later...
    • By agus
    • By Jaswinder Sandhu
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By u84six
    • By John Nguyen
