Avinash Hidadugikar Posted January 13, 2019 Posted January 13, 2019 The Es File Explorer app is missing in the LG Content Store. Also, Jio TV App is not in the content store. Third-party installation is not at all possible. Does anyone have a way to install Jio TV App on LG 49UH650T Quote
0 George Hofmeister Posted January 13, 2019 Posted January 13, 2019 Hi, In order of your queries: ES File Explore is not missing from the LG Content Store, it is just that ES Global have not yet produced (to the best of my knowledge) a webOS (non-Android) version for the platform. Jio TV is not missing from the LG Content Store, it is just that ES Global have not yet produced (to the best of my knowledge) version for the platform. Third party installation is possible if you 'hack' the system (plenty of information available on other sites), but you still will not be able to install Android or Linux apps on it unless you re-write and re-compile the apps for webOS. You will be able to install Jio TV as soon as they produce it for the webOS platform. Quote
Avinash Hidadugikar
