EPG problem
By PVD
By hollean
By AJO
By BozaB
I need help, I bought LG Oled 65 C41 LA tv two days ago, tv is working mostly fine, except when I watch LG installed streaming platforms ( Netflix and MAX tested ) tv freezes and after about 10 seconds it restarts. It does not have any pattern as far as I know, sometimes I can watch 20 mins, last two times after six minutes it crashed and restarted automatically. Can someone please help me, how can I resolve this issue? Did someone had sam problems already? Is my tv broken or I can do something to fix it?
By DeJaVu
Peter Thomas
I' just bought a 65UK6750PLD and updated to Software_File(Version_04.10.30).
When using the EPG on either freeview or Freesat, I cannot select the program I want to watch, or the channel I want to change to. Pressing the OK button on the standard IR remote, the Magic remote or the android app does nothing unless I unplug the TV and restart it. The OK button works under all other conditions.
Anyone know of a permanent fix?
Thanks for any help.
