MLB TV no longer supported on LG TV's?
    • By Evelynn
    • By Stephen Davies
    • By Brianco
      Hello
      We have an LG55UQ75006LF 2022 model. Until recently we were getting Dolby Atmos on our Creative soundbar. This was via Disney+ as well as numerous clips on YouTube. Now only Dolby Digital plays. We haven't altered any settings, so cannot understand what has happened. There has never been an option for Dolby Atmos in the TV settings, so assume it was some kind of pass through.
      Any advice would be greatly appreciated. Thanks
    • By matesz
    • By dolbnya
