Zee5 search option
By garamja
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Mohammad1403
Hello there,
Is it possible to turn off search on the home screen, or filter results to show only apps? Ideally, I'd like to limit content to be appropriate for kids.
By duckie133
VERY ANNOYING!!!!!!!!!!
By Cash
Have LG OLED 55B36LB bought in 2023 in UK.
Trying to change area option from 3122 (EU-UK) to 4816 (AJ-India) using a service remote.
It does not update or change.
any help for guidance will appreciated.
Achyut Gattu
I cannot find the search icon in Zee5 app. Can you please help me out. Thanks!
