  • 1
Update to WebOs 3.0
On 2/3/2019 at 11:52 AM, Michell B said:
How do I update from webOS TV version from 1.4 0-2529(Afro-Ashley)?
Check if there is a newer update on the LG website for your particular model, if there is it should install via OTA updating if you have that turned on.  If it does not come via OTA updating then you would need to manually install it via a USB drive.  If there is no update then you will be stuck on the version currently installed.
    • By OliverRC
    • By Ajothen
    • By Batman
