Hi there,
I have a 55" WebOS2 tv.   Connections allow you to link to a Bluetooth sound bar.   I have bought 2 LG sound bars the first ended up with the connectivity optical cable connections in both the tv and sound bar breaking.   The second using LG Sound Sync keeps dropping out whenever I receive a WhatsApp message on my LG G6 mobile.
So I have bought a BOSE SoundLink Revolve Bluetooth device so I can get good sound without interruptions.   I set up the TV to use Bluetooth, on the mobile I downloaded the Android app for Bose to connect and the unit works fine with the mobile.   Try using it with the TV and it does not work.   There is a Bluetooth output for sound bars on the connectivity page but this has no effect.
I even tried using the wired option from the USB to the Bose Soundlink Revolve.   No good.   Any suggestions.
My TV is the UG87OV
Software Version 04.05.70
Running Web OS2
John
