Volume question
By Fricassee
By Wondering
By Danilo Peixoto Ferreira
I wish I could control the volume of my LG TV 65NANO96SNA (webOS 4.50.71) using Apple TV 4K 3rd Generation (tvOS 17.3) with HDMI CEC (Belkin AV10176bt2M-BLK cable). The Apple TV has it on Settings, however, the TV does not respond to it. Turn on/off works. Volume control only works with IR. Could we prepare an update to support and fix it?
By RCarlton
I have a 2 year old LG smart TV and A LG soundbar. Periodically the volume will drop way down and when I turn the TV off and on it restores to regular volume. TV or soundbar? Any ideas?
Bart Welter
why is the volume so low unless it is increased to 15+
