Headphones
By hollean
By Fredrik Andersson
By John Nguyen
By janisad
I have an LG 32LJ610V TV.
By Evgeny Dubnov
I intend to buy LG TV 43UK6300Y.
So question: if this TV require the Bluetooth headphones which must support LG sound sync (wireless) function.
If yes, could you send the list of acceptable Bluetooth headphones.
Thank you,
Evgeny
Regana2
How do I know which headphones are compatible with my LG webOS TV LJ5500?
6 answers to this question
