Sk85 subtitles.. did everything.. nothing work
By Horniak
By CJ Catalano
By JRay
By P.T.
I have a LG G3 Oled Tv 65 inch. I want to record Tv programs using the correct USB HDD . Could some one out there give me some specifics of a USB HDD that will work on my TV .
Peter
- 0 replies
- 1,871 views
- 0 replies
- 2,131 views
- 0 replies
- 1,875 views
How can I switch between audio tracks and subtitle languages in Smart Share (webOS 2)
By David Póka,
- AudioSmart Share
- Subtitle
- (and 1 more)
- 0 replies
- 5,150 views
Yaniv Davidi
I just bought the LG sk85.
When I try to play movie from my PC who is connected via hdmi to the TV, the subtitles on the LG player app works only in English.
Everything else changing the subtitles- color or size but the subtitles language doesn't change.. only English.
Of course the .srt is the exact name as the mkv name and the in the same folder...
Please help.. tried everything..
10x
7 answers to this question
