Vocals instructions aren't working - error 6022
By Roy Brown
By Rex G
By Marko00
only with cancel button.
How to fix it?
By sudar shan
By NaveenKumar
Latest version of sun NXT app version 8.0.20 is not working for web os Tv version 4.4.2-11 plz do the needful full & Airtel Xstream is not found in your web os platform kindly check on that too
- 6,958 views
- 2,745 views
- 5 answers
- 9,971 views
- 7 answers
- 14,012 views
Francis84
Hi there,
I've just bought an oled55c8pla and vocals instructions are not working. When I try to use them a message pops up saying temporary connection error with server. Retry later (6022).
On web browser vocal dictation is working perfectly so magic remote is working as well.
Any tips? Already checked for updates (latest is 04.10.30), reset done, all agreement on user allowed, but nothing is solving.
A solution will be really appreciated.
6 answers to this question
