- 1
Adding satellite to tv
By OhmorrowSouthWales
By Michael Hirons
Can anyone advise me whether this tuner is "generic" or freesat? and i would like advise on using it with a Sky+HD satellite dish.. any advice/help appreciated as im cancelling sky contract soon Michael
By Tony Levy
I live in Spain hence the two systems. When I press the home button on the remote the list is at the bottom and displayed are LG Content Store HDMI3, LiveTV Freesat etc but no button with the aerial option, so the only way I can switch is to go into the main settings menu select Programme Tuning and switch the programme mode from Satellite to Antenna.
By leader6234
Hey guys !!!
Thanks in advance !!!
Mahboobeh Nazouri
How can I add yahsat to my satellite list webos lg tv????
