WEBOS Won't Load - 3 spinning dots!!
By Hasan Ghasabi-Oskoei
Can you help?
By Roy Brown
By Khelben Arunsun
By magicschooldropout9
By AmuLulu
ken325i
Need some help with my 55B6.....can't get the firmware to update......I have 3 spinning dots!!
Here is what has happened.....
- When watching I was getting the screensaver fireworks for no reason
- As done in previous situations, I triggered "reset to initial settings".
- the 3 colored spinning dots were triggered as if the reset had started, but no reset occurred.
- the 3 colored spinning dots would not go away.
- I downloaded the firmware to USB and tried to update using the manual USB update process per LG's online instructions.
- When I turn on the TV, with USB inserted, I still get the 3 colored spinning dots -- NOTHING HAPPENS!
I have tried 2 different USB drives and formatted both to FAT32, no success. Can't get past the 3 spinning dots!
Don't know where to go with next step!!
Thanks for any help you can provide!
Ken
