Loses connection to wifi
By akhil7j
By Ramesh Chand Vishwakarma
Regards,
MD/CEO
Noida, UP
+91 9910246766
By Guest
Things that I've tried:
factory resetting the tv leaving the tv unplugged to delete cache using google's DNS on the TV using a wired connection Having said so, I am so lost that I would be happy to try anything again.
By Trung Hiếu Trần
Specs: LG OLED 55C3
Router speed: 250mbps
System: webOS 2.3
Any ideas on how to fix it?
gannecharico
My LG 6090 smart TV loses connection alot now,and if I unplug it and plug it back in it works for a while all my other devices works fine and help? I've changed my 5g to channel 36 and even took of the quick start but no luck. Please help, beginning to think there is something wrong with the tv
