Disable auto scan of certain folders
By Venkata
Hello Team,
By mycop
Greetings.
By Pranay Mokida
By Flavio_S
By StanJ
I've seen an older thread on this topic but it doesn't look like anyone found a solution to disabling the screen saver, so I'll try a new one.
On virtually all my LG TV's (I have three OLED's and two LCD), the screen saver interferes with my music app (like Plex, Spotify or Amazon Music). I mainly use Plex for playback of my music which is stored on a central server (NAS) and from the app loaded on a Fire TV stick or cube. After about 20-30 minutes, the album art and other related music information (lyrics, song title, duration, etc) all goes black. If I run Plex (or Spotify) directly on the LG TV via the LG Content store app, the screen saver with fireworks always comes on in about 2 minutes.
I've tried all the different methods to disable the screen saver function including turning off the Timers, Auto Power Off, HDD Storage, etc. I also tried opening the hidden menus by pressing the mute button 5 times but that menu didn't have anything relevant.
Interesting is that the screen saver doesn't come on when using Spotify on a Fire TV stick or if I playback music through a USB device. But i don't use those methods often, mainly Plex to access my music server where I have about 500 CD's stored in ALAC format.
Has anyone found a way to disable the screen saver function? I know the logic for having it (to prevent OLED burn in) but I'm not leaving the same image on for more than the song duration (about 3-5 minutes). It's annoying to check the screen for the a music title or see who is on only to find a black screen looking back. Thanks for any help.
Ahmed A
I recently copied some backup folders (like steam game backup folders, etc) from my PC to my USB drive that's connected to my LG TV running webOS.
Since then, my TV takes 4x the time it previously took to show my USB drive as connected after its switched on.
So i assume that it scans all the folders to show any viewable media content .. and the new folders I copied have a lot of files and folders in them so thats adding the time to it.
So my question is, is there a way to prevent\disable the LG tv from scanning specific folders in the USB drive?
In Android it can be done by copying the .nomedia file into the desired folder, but I don't know how its done for LG's webOS.
thanks for help.
