Arnaud Posted April 11, 2019 Posted April 11, 2019 Hi I own a 55UG870V smart tv with firmware that has recently been updated to 04.05.80 Since this update, Wifi is non functionnal each time I start the TV. I have to deactivate WIFI and reactivate it and then the TV reconnects without issue. ( trying to reconnect without deactivate/reactivate doeqn't work) Is this a bug ? Does anyone suffer the same issue ? Thank you Regards Quote
Arnaud
Is this a bug ?
Thank you
Regards
