Netflix
By Nicola123
By svsrama
Sriram.
By cptl
Any thoughts?
By Sandtonman
Dolby Vision is 22.11.
By Edgar Corona
I have a 55" smartv, i'm having problems with Netflix app, anyone knows why, i can't open de app, everything after and update send it by the tv..
Maureen Harty
I can't run the Netflix app on my tv. Keep getting tvq-pm-100 error. I have already
1. Checked for app updates
2. Unplugged my Xfinity cable box for 3 minutes
3. Unplugged my tv for 3 minutes and nothing is working
Link to comment
Share on other sites
4 answers to this question
