TV keeps increasing the volume.
By sbal
So sick of this stupid piece of crap TV. Every couple of days, the TV logs me out of my LG account and I can't use the IPTV channels.
Besides how incredibly and utterly stupid it is to require a f'in "account" to watch TV, when I go to log back in on the TV or the app (again I can't believe I need to download a f'in app to watch TV) it doesn't work. I need to change the location to Canada, reboot the TV, change the location back to US, reboot the TV, and then I can log in and am presented with the "terms and conditions" I need to accept (for the love of God why in the f'ing world do I need to accept terms and conditions to watch f'in television!?!?!?!). Then I click "Accept All" and everything works, for a few days, until it logs me out again for no reason and I need to go through the entire circus again
The TV is hard wired to Ethernet, so it's not a wifi issue. It's on a battery backup so it's not a power interruption issue. Anyone know how to fix this? This last time I went into the menu and the account and clicked the "Check Terms and Conditions" and there was a entry on the bottom with the green check mark so I clicked "Accept" on that one, I'm hoping that does it?
Needless to say there is no way I would ever consider for even a second buying another LG product, I will never give another dollar to a company that makes products so incredibly hostile to customers. but I spent a lot of $$ on this TV and I'm going to be stuck with it for a while so I am hoping this is fixable, despite how utterly ridiculous neededing to have an account or accept terms and conditions to use a device I bought and own
By Nicola123
By Flavio_S
By Danilo Peixoto Ferreira
I wish I could control the volume of my LG TV 65NANO96SNA (webOS 4.50.71) using Apple TV 4K 3rd Generation (tvOS 17.3) with HDMI CEC (Belkin AV10176bt2M-BLK cable). The Apple TV has it on Settings, however, the TV does not respond to it. Turn on/off works. Volume control only works with IR. Could we prepare an update to support and fix it?
- 2,497 views
- 1,994 views
- 2 answers
- 2,279 views
OLED 55C7T is not supporting atmos in truehd container when playing from Hard drive after firmware update
By hellojavad,
- firmware update
- sound
- (and 3 more)
- 4 answers
- 4,003 views
AsbjornDam
Hello There,
My tv keeps increasing the volume. It differs by how much some times it jumps from 10 (my standard) to 11, sometimes to 14 and a lot of other random numbers between 10-100, it appears on the screen and the number increase in speed as someone is pushing a remote.
Some facts from my situation:
- I know it is not my own remote, as i've tried removing my remote batteries.
- Theres no one on my network, except me.
- It tends to happen more and more, the longer the tv has been turned on.
- If i put my TV on standby, it turns on the next time it increases the volume. (This is not happening if i press the volume button on my magic remote, BUT it does happen when i use the joystick beneath the screen)
My TV model is LG UF772TV and i currently run on webOS 04.25.85
i hope someone knows what to do, as it is seriously annoying.
I dont have warranty anymore.
If you have any questions, just shoot!
Best Regards
Asbjørn Dam
