- 2
lg smart tv [iptv smarters player]
By Will M
By Lesbo
By wallyricks
By Rex G
Hutchy
brand new lg amart tv
loaded iptv smarters app no problem
put in username and password
username and password are correct
keeps coming up
failed to authorize
any help would be appreciated
7 answers to this question
