    • By David Daul
    • By 43UR81006LJ
    • By Ramya Shyam
    • By Tom S.
      New user to the forum!
      My TV is an LG OLED 65B6P, which was working fine until a few days ago, when the magic remote pointer and OK button stopped working (was getting message that Bluetooth needed to be initialized).  After making the mistake of calling product support, they had me do a factory reset, but that didn't fix the issue, and only made it worse, as now I can't proceed from the "Start Up" menu as I can't click the OK button.  I'm dead in the water, and have even tried this with 2 different magic remotes!  I've tried the pairing and unpairing suggested on numerous support sites, and can't get anywhere with this.  Can't even find an LG service center in the Boston area.
      Any help is appreciated!
