Exists a bug/error that you cannot up/down the volume when use an apple airpods connected to the TV, it works mute, but not up/down volume. Seems that with an update to the webos fix the problem.?
    • By JamesH
    • By Fredrik Andersson
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By Kane Murphy
    • By janisad
      I have an LG 32LJ610V TV.
