Disable Wi-Fi button on and off
By mycop
Greetings.
By Dennis Radliff
By JonoW
By Marko00
only with cancel button.
How to fix it?
i3oi3oy
Hi, my TV is the lh600t model. After the last update and installation of WiFi and Bluetooth and my magic control, I got in trouble and turned off.
