    • By Marko00
      only with cancel button.
      How to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Muser
    • By JeanF
      In the favorites list, the last favorite is added at the end of the list. How to change/sort the sequence of the favorites ?
