Hi im not sure if this is the place to post a question like this  sorry it its not.
I have and LG TV which has been having problems with SKY Q blacking out. I got in touch with LG and they said I needed an update which they sent me on a disc.
I followed the instructions but my TV wont read the epk file so wont sense it needs to update. I have tried numerous usb drives I have formatted them in ntfs and fat. The usb reads they LG_DTV file but says there is nothing inside. Any help would be great thanks.
  • 10 months later...
    • By Lorenz
    • By MinoDc
      Hi to all.
      What do you think
    • By williamsats
      Hi everyone!!!
      Lately I have a problem with my 40UH630V (OS Ver. 05.70.30). It takes too long for a hard drive or a USB stick to get it ready to play video files. That means that I have to plug in my hard drive or USB stick and wait for at least 4-5 minutes before I can play the video files, no matter what type/format they are. Sometimes I have to unplug and re-plug my drive so to read it.
      Here I must point that both USB ports are clean with no dust or any corrosion, USB cables are new and fully functional and all hard drives and USB sticks are working perfectly on my 32LQ63806LC.
      Also in some cases i get a message on TV for a format compatibility but I don't think this is the case, since if I wait 4-5 minutes (sometimes a bit more) then it reads them normally.
      Any ideas?
    • By odesanmi kolade
      I have been trying to downloading Aptoide TV on my LG smart Tv but keep showing File downloading not supported.. My goal is how I can get zoom conference app running on my Smart Tv. Please help!!!
