Wifi Issue
By agus
By RJ Fischer
By Regis Wheeler
By JasonB
By AMK
Tv model 55UJ630V-TA
Sw version 06.10.50
naresh gorak
I have LG webOS TV LJ554T when trying to connect the wifi its now getting connect its shows the status as checking... And gives error message Unable to connect to the network. Unknown issue has occurred. Please check the status and try again.
Wifi is working fine in all the mobile devices. Tried connecting with ethernet cable and ot also shows the status as checking..
