C8 - Streaming 4K movies - MacOS
Hey LG mates,
I have just bought OLED C8 and I am reading all the articles about streaming movies from PC to my smart TV, but I am not successfull at all.
1. I have 1Gbps internet, but all of my devices are connected to Wifi. Speed tests display 100 Mbps for download and upload maximum so I suppose that the router is not the best one. I have router right behind the TV, so maybe this will not be the best place after all. Should I use LAN cable for both devices or only one of them? I have bought CAT6, but as I read that the TV supports only 100Mbps through LAN cable, I am not sure if this will help for 4K movies.
2. I downloaded Plex to my MacBook Pro 2017 and my LG as well, but I was not able to stream anything. 1080p stopped in the beginning and was buffering for more than 15 minutes so I closed the application. What should be the proper set up of PLEX?
3. What preferences should the movie file have?
6 answers to this question
5 hours ago, Mejriou said:
Hey LG mates,
Get yourself a Raspberry Pi, version 3 would do but they have just released the 4 with up to 4GB of RAM.  Then install DietPi which makes the set up Plex Media Server and other programmes really easy, add an external drive and you should be set to go.
The format of the media should not be a big issue as the Plex Media Server will encode it in a format suitable for the device seeking to view it.
I have watched 480p 720p videos of not particularly great quality streamed to my 2016 49" LG from a RPi 3 and the results have been more than adequate.
100Mbps networking should only be an issue with 4K if the media have been encoded at a really high bitrate/quality etc.  If the cable is not quick enough then maybe it is time for faster WiFi.
On 6/26/2019 at 4:30 PM, Mejriou said:
Hey LG mates,
I should use LAN on both devices. On wifi you always can get problems with neighbours of you microwaves.
Think about using a powerline adapter to connect the router to your Mac via the power lines in your home.
I use a TP-LINK AV2000 and it is fabulous. I have my router behind the TV so it plugs directly into the LG TV. Then I use the power line adapter to connect router to Mac mini which is in my study. The speeds are much better than wireless.
There are ways to connect your Macbook to the LAN see here:
 for an example.
In my case I have a QNAP NAS that holds all my media.  It also runs a Plex server (so I don't have to use my Mac for the server). It plugs directly into the power line adapter also.
Cheers.
That is a possibility but I would never use it. As a radio amateur I know these things can cause a lot of interference because they inject HF signals into your power lines.
If it is your own house invest a zaterdag to make a LAN network to all your rooms.
YMMV
On 6/26/2019 at 8:00 PM, Mejriou said:
Hey LG mates,
100mbps is sufficient for most 4k files. Makes sure you have direct play enabled on the plex client. I stream 80gb HEVC HDR movies over wifi ac and they play seamlessly. Direct play is the key.
I have two 4K tv’s and none of them are hardwired.
1080p should be a cakewalk.
have you performed speedtest on the tv? If it is also close to 100mbps then you don’t need to worry.
also  check status on the plex server when movie is playing. Is it showing transcoding?
Hello there,
I am probably going to buy new Rapsberry 4B in with 4 GB RAM. Do you think that it will easily play 4K HDR movies with bit rate over 50 Mbps to my LG TV? I have no experience with it so I am wondering what limitations there might be.
    • By NickL
      Br,
      Nick
      LG Radio+ Brings LG Smart TV Users Free Listening to a Wide Range of
      Popular Podcasts and Live Stations, Also Accessible From LG’s Audio Devices
      SEOUL, Dec. 20, 2024 — LG Electronics (LG) has launched LG Radio+, the company’s ad-supported audio streaming service, now available on LG smart TVs running webOS 6.0 and above. This new service allows users to effortlessly access a diverse selection of podcasts and radio programs. For a streamlined user experience, LG Radio+ will work with the LG ThinQ app,1 providing users with a convenient way to access and enjoy their favorite audio content no matter where they are in the room.
      To offer a curated list of audio streaming content, LG has partnered with global radio and audio provider Radioline, giving users an all-in-one audio platform allowing effortless access to news, sports, music and more. Available in the U.S. and Korea, LG smart TV users can explore a range of live stations and podcasts, with options such as NPR, CNN Radio, Fox Radio or The Joe Rogan Experience in the U.S., or popular local stations and podcasts in Korea.
      The LG Radio+ app can be accessed from the Content Store or Apps or by using the voice search function of the LG Magic Remote, providing a fast and convenient way to discover new listening content.
      For quick and easy exploration, LG Radio+ has an intuitive interface with a comprehensive channel list, presenting popular audio channels on the On Air page, alongside a personalized selection of favorite channels. Users can navigate the On Air and Podcast pages to access their desired audio streaming content, while the Featured page provides a dynamic view of trending music, updated in real-time to highlight the most popular or season hits. This enables users to search, discover and enjoy their preferred audio content with ease out of a large library of over 14,500 channels in the U.S. and over 440 available in Korea.
      As part of LG’s commitment to enhancing user convenience and connectivity across the company’s life-enriching products, listeners will be able to access LG Radio+ through the LG ThinQ app,2 enabling enjoyable audio streaming on LG audio devices with minimal effort. What’s more, LG Radio+ will also be available to access through the My button on xboom speakers in 2025.
      LG continues to elevate the user experience with a broad range of content and an intuitive user interface, making it effortless to explore and enjoy audio entertainment. To learn more about how LG is enhancing the audio experience, visit
      1 Available at a later date in 2025.
      2 Accessible via xboom category
      LG TV Owners Worldwide Gain Access to Exciting Offers, Including Discounts
      and Free Trials from Global and Regional webOS Content Partners
      SEOUL, Aug. 30, 2024 — LG Electronics (LG) is announcing the LG Streaming Week campaign in 44 countries, starting from September 9 and running through October 13,1 to celebrate a decade since the initial launch of webOS on the company’s LCD and OLED TVs. For owners of LG TVs above UHD released from 2018 onward (running webOS 4.0 and above), as well as StanbyME and StanbyME Go users, LG Streaming Week presents a variety of free and discounted subscriptions from service partners through its dedicated app, accessible from the Home Screen, Content Store or Apps.
      Each promotional week will feature a different global and local partner line-up, with each partner limited offer accessible and redeemable solely on a weekly basis, from the LG Streaming Week app.2
      LG Streaming Week boasts a range of enticing offers from content partners, such as free subscriptions of up to three months and up to 90 percent in discounts. Whether a fan of movies, sport, gaming, anime or cult classics, LG Streaming Week caters to a multitude of interests and preferences for a more captivating viewing experience.
      Apple TV+3 is offering a three-month free trial, allowing LG TV owners to enjoy the latest premium Apple Originals, including the gripping psychological thriller Disclaimer, starring Academy Award-winners Cate Blanchett and Kevin Kline and created and directed by five-time Academy Award-winner Alfonso Cuarón. Plus, new seasons of the Emmy Award-nominated and BAFTA-Award winning drama Slow Horses; enthralling post-apocalyptic series Silo; and the sweeping and deeply moving drama Pachinko. Moreover, LG is providing customers with a three-month free trial of Apple Music.4 The award-winning Apple Music offers one of the largest catalogs of music in the world with over 100 million songs as well as over 30,000 expertly curated playlists, artist interviews, Apple Music Radio and so much more. Apple Music subscribers also have access to exciting features like Apple Music Sing and time-synced lyrics as well as lossless audio, and immersive Spatial Audio.
      Movie enthusiasts will be delighted with the chance to explore films and series from multiple content providers across genres. New and returning Paramount+5 subscribers can get a 50 percent discount on an annual subscription of high-stakes dramas including Tulsa King, critically acclaimed projects like Fellow Travelers (Paramount+ with Showtime plan only in US), next-gen franchises that build on fan favorites like Knuckles, Star Trek: Strange New Worlds and Tales of the Teenage Mutant Ninja Turtles, along with an extensive library of even more hit series, blockbuster films, live sports and breaking news.
      Mubi,6 a global streaming service, production company and film distributor dedicated to elevating great cinema all over the world, is offering LG TV owners during LG Streaming Week a chance to discover the best of cinema, in the comfort of their home, with 70 percent off for six months.
      For sports fans, DAZN7 – the only place to watch NFL Game Pass (excluding US and China) – will be offering new customers 25 percent off a NFL Game Pass Season Pro subscription and a NFL Weekly Pro subscription for USD 0.99 or local currency equivalent. This will give LG TV owners the opportunity to watch every NFL game from every team, including the Playoffs and Super Bowl, live and on-demand. Plus get NFL RedZone, NFL Network, NFL Originals and much more, including a full suite of archive content.
      What’s more, for those who prefer gaming or anime, LG Streaming Week has appealing offers for users of different tastes and interests. LG TV owners can embark on an anime adventure with 30 days free trial of Crunchyroll, where fans unlock the largest dedicated anime streaming library of over 25,000 hours of content and fresh series arriving every season. For an interactive experience, especially for LG TV owners, Blacknut8 Cloud Gaming offers a 30-minute free play session for any of their 500+ premium games and a special USD 1/first month subscription offer for new subscribers. For kids and families, Baby Shark World for Kids by The Pinkfong Company is granting 1 month of free access to its vast library of songs and stories that engage children in stimulating learning experiences.
      To provide those who do not yet own an LG TV with the opportunity to take advantage of LG Streaming Week, the company is presenting several promotions on TV products across the global market. LG aims to expand its presence with enticing occasions for users to experience all that webOS has to offer on LG TVs.
      The decade-long journey of webOS is marked by continuous innovation, demonstrating LG’s commitment to delivering content with a user-friendly interface for convenience and ease of use. Over the years, webOS has undergone a home screen overhaul that enhances usability and leverages the latest AI technology to effortlessly direct viewers to their preferred content. What’s more, the company’s recent webOS Re:New program enables LG AI TV owners to receive TV upgrades for a period of five years, enriching the user experience for a wider audience.
      LG webOS highlights LG’s dedication to optimizing content consumption, with support from over 4,000 partners in 180 countries and millions of active users. Since its launch, webOS has evolved over 10 years to transform the home entertainment experience for easy-to-use viewing pleasure. Now available across LG TVs and lifestyle screens such as StanbyME and StanbyME Go, webOS has recorded significantly increased usage time, with consumers gradually shifting access from traditional TV to webOS, reflecting its widespread appeal to users around the world.
      For further details about free and discounted content available during LG Streaming Week, visit the dedicated page on each regional LG.com site. Information on LG product promotions can also be found at
      link hidden, please login to view. ###
      1 LG Streaming Week 1 starts September 9 and redemptions for Week 1 offers close September 15. Week 2 starts September 16 and redemptions for Week 2 close September 22. Week 3 starts September 23 and redemptions for Week 3 offers close September 29. Week 4 starts September 30 and redemptions for Week 4 offers close October 6. Week 5 starts October 7 and redemptions for Week 5 offers close October 13. Select partner offers may start at a different date than the beginning of the week.
      2 Partner offer can only be redeemed once via LG Streaming Week app.
      3 Apple TV+ offer is available via LG Streaming app from September 9 and can also be accessed directly from Apple TV app in over 90 markets until November 17. Offer ends November 17. Offer available on 2018-2024 LG 4K, 8K Smart TV models, StanbyME and StanbyME Go models in the Apple TV app. Valid only for new and qualified returning subscribers to Apple TV+ in your region. Limit one offer per TV and Apple ID. Plan automatically renews at your region’s price per month until cancelled. Requires Apple ID with payment method on file. Payment will be billed to payment method on file and can be cancelled anytime at least a day before each renewal date in your service account settings. Terms and Apple Privacy Policy apply; see the applicable terms at Must be the minimum age required in your country and in the country that matches the store front on which you are redeeming the offer. Compatible products and services required. Cannot be combined with other offers providing access to the same service. Apple TV+ is a service mark of Apple Inc.
      4 Apple Music offer is available via LG Streaming app from September 9 in 44 markets and can also be accessed directly from Apple Music app in 137 markets until April 30, 2025. Apple Spatial Audio with Dolby Atmos is available on LG OLED TV models launched from 2018 to 2024 and QNED TV models Q90T and above.
      5 Paramount+ offer is available in 18 countries including US, Canada, United Kingdom, France, Italy, Austria, Switzerland, Republic of Ireland, Australia, Argentina, Brazil, Mexico, Colombia, Chile, Peru, Panama, Guatemala and Ecuador, where LG Streaming Week promotion is available. The total cost of the annual plan is billed upfront and after the first year, auto-renews at the then regular annual price of the annual price selected. Paramount+ U.S: Total cost of annual plan billed upfront. Auto-renews at then regular annual price (currently, plan start at USD 59.99/year + tax, as applicable).
    • By BGee
      On my LG 60SJ850T, Watching Horizon from AppleTV streaming service. Western with some scenes with Apache language being spoken. No subtitles appearing. When CC is on, see “foreign language being spoken”. When viewed on iPhone, there are subtitles. Have tried same movie using chrome cast TV, and casting from iPhone to Apple TV device. Never get subtitles. Verified subtitles work when I stream to same chromecast TV connected to a different TV.
      reset LG TV to factory settings after trying all available CC and subtitle settings on TV. Still no subtitles.
    • By SHUZ
      I have several LG Webos TVs.  One started doing this a long while back.  Just this week another started doing the same. They have streaming devices on hdmi ports.  To change channels and general navigation i could always use the up down left right buttons.  But now I get the he hdmi port with the multi audio icon below.  Something has to have been toggled to make this happen.  Factory reset doesn’t fix it.  How do I access my streaming device from my lg remote again?
