OLED55C6V videoplayer displays green shaded picture for some Dolby Vision videofiles
When I try to play some Dolby Vision video on my OLED55C6V from USB-flash or from DLNA-server (without any conversion) by the internal application for photo and video playback I see the picture painted green. Some Dolby Vision video is played properly. So can I change something in my television settings or in the video-file (I would be able to re-encode or remuxe it if I knew what should I change) for fixing the problem? Thank you beforehand!
Mediainfo file dump:
General
Complete name                            : N:\02.Chameleon.mp4
Format                                   : MPEG-4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/iso6/isom/msdh/dby1)
File size                                : 530 MiB
Duration                                 : 1 min 2 s
Overall bit rate                         : 70.9 Mb/s
Encoded date                             : UTC 2019-06-13 18:12:29
Tagged date                              : UTC 2019-06-13 18:12:29
Video #1
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Bit rate                                 : 55.6 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.280
Stream size                              : 416 MiB (78%)
Default                                  : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level              : 1000 cd/m2
Maximum Frame-Average Light Level        : 60 cd/m2
Codec configuration box                  : hvcC
Video #2
Format                                   : HEVC
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : dvhe
Codec ID/Info                            : High Efficiency Video Coding with Dolby Vision
Bit rate                                 : 13.6 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Color space                              : YUV
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.274
Stream size                              : 102 MiB (19%)
Default                                  : No
Codec configuration box                  : hvcC+dvcC
Audio
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Format profile                           : Blu-ray Disc
Codec ID                                 : ac-3
Bit rate mode                            : Constant
Bit rate                                 : 1 664 kb/s
Channel(s)                               : 8 channels
Channel layout                           : L R C LFE Ls Rs Lb Rb
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Bit depth                                : 16 bits
Compression mode                         : Lossy
Stream size                              : 12.5 MiB (2%)
Language                                 : Russian
Service kind                             : Complete Main
Default                                  : No
Complexity index                         : Not present / 16
Number of dynamic objects                : 15
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
Posted (edited)
@Николай Долбня It is possible that one of the "expert mode settings" is not correct for some media types being decoded. I did see mention of a bug in some sort of "lookup table" for this stuff, in another forum. Try temporarily turning off the "dynamic tone-mapping" in settings -> Picture -> Picture Mode Settings. Then see if the affected test videos are improved or not.
If no difference, try testing with other modes off or on as needed, BUT- DO REMEMBER your initial settings, so you can get it back to your normal settings for regulat TV viewing. Take a photo of your settings on your phone or camera before starting changing anything.
NOTE: if you DO find that (e.g. dynamic tone-mapping) is the culprit, then report it to your country LG Support site, as this forum is ONLY a peer-to-peer enthusiasts forum, and is NOT OWNED OR RUN BY LG. If users do that, then there is more chance of a fix from LG.
Edited by td47
typo
      Company Leverages Its Latest AI-driven Innovations to
      Expand the Definition of Space Experience
      SEOUL, Jan. 2, 2025 — LG Electronics (LG) is showcasing an innovative, new solution that extends the convenience and comfort of the LG AI Home into mobility spaces at CES 2025. The “Lifestyle Solution for Mobility” concept vehicle, on display at the company’s booth, introduces the LG Mobility Experience (MX) platform. This groundbreaking mobility space solution integrates a full suite of LG’s smart life solutions to create a seamless connection between mobility and the AI Home, offering entirely new lifestyle experiences.
      LG’s MX platform expands the definition of home solutions, creating a new type of multifaceted, multipurpose space. Using a modular package system, the platform integrates LG’s innovative appliance hardware and AI technologies to transform the vehicle cabin into an adaptable environment. This space can function as an extension of the home, a private media lounge or a creative studio, unlocking a raft of exciting “Space-as-an-Experience” opportunities for potential customers.
      The MX platform aligns with prevailing auto industry trends and customer preferences, which are shifting away from traditional notions of transportation and towards the idea of vehicles as a personalized lifestyle space. The platform offers a tailored lifestyle experience where the latest products, AI solutions and services synergize to support superior user comfort and convenience.
      The MX platform features a dual-cabin design: a front driver’s cabin and a rear customizable experience space. Users can configure this versatile space in a variety of different ways, such as dividing it into multifunctional zones or converting it into a hyper-personalized lifestyle spaces complete like a creator studio, business lounge or separate zones for relaxation and hobbies. The modular design makes it possible to equip the rear cabin with various appliances, enabling users to select combinations that meet their particular needs and preferences. LG plans to offer the MX platform as a subscription service, making it accessible to a broader audience.
      Powered by LG’s AI Home solution, ThinQ ON, the MX platform lets users tailor conditions inside the vehicle and enjoy helpful lifestyle services such as daily schedule management and information briefings. Additional services from external providers – including food and beverage order, laundry and hotel booking – can be integrated to further expand and enrich the user experience.
      Visitors to LG’s booth at CES 2025 can explore the MX platform in the “Lifestyle Solution for Mobility” experience space. This will showcase highly-customizable space solutions and mobility lifestyle solutions, featuring LG’s state-of-the-art appliances and Internet of Things devices. It will offer a compelling preview of the future of mobility and connected hybrid living spaces.
      “The innovative MX platform, based on the concept of ‘Space-as-an-Experience,’ leverages LG’s strength in appliances and AI Home technology to present a new direction for mobility experiences,” said Lyu Jae-cheol, president of the LG Home Appliance Solution Company. “Pursuing our Zero Labor Home vision, we will continue to connect and expand customer experiences across all aspects of daily life.”
      Visitors to CES 2025 from January 7-10 can experience all of LG’s latest innovations, including the MX platform, at the company’s booth (#15004, Las Vegas Convention Center).
    • By Gregor Huc
    • By Kane Murphy
      Strategic Restructuring to Enhance Synergy and Drive Growth in Key Business Areas
      SEOUL, Nov. 21, 2024 — LG Electronics (LG) today announced a series of organizational changes and executive appointments following the approval of its board of directors. This restructuring aims to accelerate the company’s mid- to long-term strategy, “Future Vision 2030,” by enhancing inter-organizational synergy and innovating its business portfolio.
      The restructuring focuses on regrouping LG’s business operation units* to maximize the potential of existing businesses, strengthen platform-based service operations, accelerate B2B initiatives and secure new growth engines in promising sectors. These changes are designed to enhance efficiency through the strategic selection and concentration of capabilities, thereby creating greater synergy between businesses and bolstering future competitiveness.
      To spearhead this transformation, LG has appointed skilled individuals with exceptional expertise, emphasizing the enhancement of the company’s long-term competitiveness through the development of high-performing organizations.
      Key Changes in Business Structure
      A new Company will be established to bolster the growth of the heating, ventilation and air conditioning (HVAC) business, a crucial component of LG’s B2B acceleration strategy. The Overseas Sales & Marketing Company will now function as the overseas B2B control tower. Additionally, display-based operations – including TVs, monitors and signage – will be integrated to foster synergies and expand platform-based service businesses. New growth engines will be strategically relocated to Companies with greater business relevance, ensuring more stable support and creating synergies across business areas.
      All four Companies will now incorporate “Solution” in their names, reflecting LG’s evolution into a Smart Life Solution provider that connects and enhances customer experiences across various environments, including homes, commercial spaces, mobility and virtual platforms.
      Restructuring of Companies
      LG has restructured its four Companies into the Home Appliance Solution (HS) Company, the Media Entertainment Solution (MS) Company, the Vehicle Solution (VS) Company and the Eco Solution (ES) Company. This reorganization redefines their roles and identities within LG.
      The H&A Company will be renamed HS Company to align with its vision of “Zero Labor Home, Makes Quality Time.” To support this vision, LG will move the Platform Business Center – responsible for the planning, development and operation of LG ThinQ – directly under HS Company. This strategic realignment aims to establish HS Company as a leader in AI solutions across diverse spaces, including homes, commercial areas and vehicles, effectively addressing customer needs outside traditional home settings. Furthermore, HS Company will incorporate the Robot Business Division from the BS Company to integrate core robot technologies into its home robot solutions. Lyu Jae-cheol will continue to lead HS Company.
      The HE Company will change its name to MS Company to align with its goal of becoming a media and entertainment platform powerhouse. It will integrate the Information Display business and Information Technology business from the BS Company with its TV business to create synergies in hardware and platform operations. Park Hyoung-sei will continue to lead the MS Company, driving its transformation into a media and entertainment platform.
      The MS Company will accelerate the expansion of platform-based service business areas by broadening the application of webOS, which was primarily used in smart TVs, to monitors, signage and in-vehicle infotainment systems. webOS will evolve into an integrated content and services platform for both indoor and outdoor use, enhancing competitiveness through synergy and improved business structure.
      The VS Company will clarify its role by changing its name from Vehicle component Solutions Company to Vehicle Solution Company, emphasizing its commitment to providing innovative solutions across the entire automotive ecosystem. Eun Seok-hyun will continue to lead the company.
      The ES Company has been newly established. The HVAC business, previously part of the H&A Company and a significant contributor to LG’s B2B growth, will now operate as a standalone entity under the ES Company. Lee Jae-sung, the current head of the Air Solution Business Division, will lead the ES Company, ensuring continuity in the HVAC business and maintaining its strategic direction.
      Given the project-based nature of the HVAC business and the specific characteristics of the market and its customers, LG has determined that operating it as an independent Company will maximize future competitiveness and growth potential. With the establishment of the ES Company, LG aims to position itself as a global leader in comprehensive air solutions.
      Additionally, the ES Company will assume responsibility for the electric vehicle charging business from the BS Company and play a pivotal role in driving B2B growth within the clean tech sector, one of LG’s key future growth engines.
      Meanwhile, to enhance the competitiveness of overseas B2B operations, LG will establish the B2B Business Capability Enhancement Division under the Overseas Sales & Marketing Company.
      The Chief Strategy Office (CSO), acting as LG’s future strategy control tower, will also oversee AI acceleration and respond to global AI developments. The Chief Digital Office, previously responsible for digital transformation, will be reorganized into the DX Center and transferred directly under the CSO. The DX Center will focus on driving business performance through generative AI technologies and will be led by Cho Jung-bum.
      The executive appointments emphasize the selection of diverse talents with proven expertise in sales, services and R&D. Jung Pil-won, currently leading the TV Overseas Sales & Marketing Group, has been appointed as the MEA Region Representative, recognizing his extensive experience in overseas sales management and his deep understanding of the Middle Eastern and African markets. Additionally, Kim Jung-ho, Kim Yoo-seon and Choi Jung-won, who head the subsidiaries in Saudi Arabia, Poland and Malaysia respectively, have been promoted to executive positions in acknowledgment of their significant contributions to business growth.
      All appointments are effective December 1, with promotions taking effect on January 1.
      * LG’s major business operation units are called “Companies.”
      LG Objet Collection epitomizes artful home appliances that seamlessly complement any space. And since beauty is not just on the outside, each appliance boasts innovative technology and leverages the LG ThinQ platform to ensure a smarter home that prioritizes convenience.
      To help consumers realize their dream homes – spaces that embody convenience and evoke positive emotions – LG Vietnam teamed up with AKA, a leading interior design brand that has propriety rights of over 30 famous furniture brands. Together, they crafted inspiring living space concepts showcased in BoConcept showrooms, a luxurious furniture design brand exclusively distributed by AKA. Here, the latest appliances and devices from the LG Objet Collection were prominently displayed, curating harmonious spaces that reflect unique tastes and styles.
      The living room was transformed into an art exhibition with LG OLED Posé TV. The product’s luxurious design, characterized by soft, rounded lines and a beige fabric finish, inspires a warmer, more intimate atmosphere. The Posé minimizes visual clutter by concealing cables and accessories behind its cover, while cleverly routing the power cord along the base.
      The kitchen was elevated with the LG Objet InstaView refrigerator and LG Quadwash TrueSteam dishwasher, which feature elegant designs and advanced technologies to bring aesthetics and convenience to the heart of every home.
      In the bedroom, the LG PuriCare360 Alpha PET air purifier became an indispensable element by quietly cleaning the air, ensuring the best night’s sleep. Its unique two-tiered cylindrical design added a stylish touch that accentuated the relaxing ambiance of the room. The stylish LG Stanby ME smart screen, with various customization options and effortless portability, was another popular choice for family homes.
      Another design marvel for the home was the LG Objet Styler, which boasts a modern design with minimalist square edges, resembling a small wardrobe. To ensure it blends effortlessly into any interior, its screen can be hidden away and only appears when touched by the user. Meanwhile, the LG WashTower introduced a “new breeze” to laundry spaces with its stacked washer and dryer design, utilizing a single control panel for optimal cleaning while saving valuable space.
      Beyond its pioneering and creative designs, the LG Objet Collection integrates LG’s leading technologies, allowing customers to enjoy a daily paradise of convenience. Each product in the high-end collection connects seamlessly to the LG ThinQ app, empowering users to control their devices via smartphone, ensuring spaces are always tailored to their preferences.
      Interior design experts note that the subtle yet elegant colors of beige, black and green not only allow the LG Objet Collection harmonize with a wide array of design styles but also add a touch of refinement and coziness to living spaces. These colors contrast beautifully with natural elements like stone, wood and tiles, enhancing the overall depth of the décor.
      With today’s customers expecting new products to do more with less, the experience space also showcased LG PuriCare Aero Furniture, featuring a unique design that resembles a modern coffee table. Complete with a control panel and a wireless charging pad for smart devices, its cylindrical base purifies the air while maintaining a sleek aesthetic.
      This collaboration between LG and AKA exemplifies the ideal home for modern consumers, merging aesthetically pleasing designs with life-enriching functionality. It reflects LG’s long-standing commitment to enhancing the overall user experience while promoting easier interactions with their products.
      Contributed by LG Vietnam
