Can't install Emulator v2 or v3 using Component Manager
By hollean
By anna groove
By Sqwazy
By JamieG
By Gabriel Śmiech
Jeff Tyson
I have installed the SDK, and I'm trying to install the v2 and v3 emulator using the component manager. When I click install it says Downloading but is stuck at 0% eventually it errors out saying "Network connectivity issues. Try again after some time.". I have tried uninstalling and re-installing the SDK, rebooting my computer and using a different network. Nothing seems to work, it keeps failing to download.
Please help.
--Jeff
