stuck pixel
By Maggie
The replacement remote for our lg tv (65uq7070zue) stopped working yesterday while i have kids home on winter break. I ordered a voice magic but even though i checked the specs several times and made sure the model number was specifically mentioned it won't pair and lg says it's the wrong remote. I stupidly reset the tv during this not thinking that it would totally unpair the tv from my phone remote app and it's now stuck on press the wheel/ok screen. I've ordered a lg brand remote but it'll be a couple days and it was supposed to be our movie day. Is there any way to switch the hdmi with it stuck on this screen so we can use the fire stick or playstation? Two universal remotes, one specific to lg tvs, have failed to accomplish anything as well.
By victoranthony
Hey everyone,
I have had LG TV for just two years. Last weekend, when I turned it on, it showed a blank white screen but was still illuminated, with sound working. No LG logo or image appeared. I unplugged the TV and held the power button for 30 seconds while it was unplugged, and the screen issue fixed the issue for a week[url=https://whitescreen.vip/
].[/url]
However, the same white screen problem has now returned, and the power reset trick no longer works.
Should I contact a local TV repair technician or reach out to LG customer support first? Any advice?
By Tom S.
New user to the forum!
My TV is an LG OLED 65B6P, which was working fine until a few days ago, when the magic remote pointer and OK button stopped working (was getting message that Bluetooth needed to be initialized). After making the mistake of calling product support, they had me do a factory reset, but that didn't fix the issue, and only made it worse, as now I can't proceed from the "Start Up" menu as I can't click the OK button. I'm dead in the water, and have even tried this with 2 different magic remotes! I've tried the pairing and unpairing suggested on numerous support sites, and can't get anywhere with this. Can't even find an LG service center in the Boston area.
Any help is appreciated!
By has66
I have problems with an old TV (42LB630V-ZA); the TV is working fine after start complete
but it doesn't start completely always; it display the logo and don't finish the boot
after multiple tries it starts and working fine until next start
is it posssible to re-write the software? now is at the last firmware available for this model Version 05.05.75
is here somebody to advise me how to get this resolved?
the local suport for lg is unable to resolve (I am wonder if they understand it or don't want to do it)
thank you
phillmd
I have what appears to be a stuck pixel (it is bright white) on my LG OLED TV. Is there any way turn it off? It is near the top of the screen.
