Switching On/Off Listen mode on latest WebOS
By tarakdave
By Nick Payne
By Bella Lee
link hidden, please login to view. With Tunelf Spotibeat Music Converter, you can and then transfer them to LG webOS Smartwatch for playing without limits. -
By Alex
Samsung has made fridges with touchscreens before. LG has made fridges with doors that turn transparent to show you the inside. This year at CES 2018, those two ideas are finally merging into one with LG’s new InstaView ThinQ smart refrigerator, which features a 29-inch touchscreen that becomes transparent if users knock on it twice.
LG actually tried this two years ago, with a version called the Smart InstaView Door-in-Door that ran a full version of Windows 10, but it’s not clear that the company ever shipped the Windows version.
Unfortunately, the only image that LG has shared showing the fridge is a low-resolution shot on its YouTube page banner, but it seems that you’ll be able to still use the screen while it’s translucent, allowing you to tag food directly in a vaguely augmented reality-esque move.
Source:
By Junaid Ahmed
- 1 answer
- 11,480 views
snoopman
I've bought LG OLED65E8 TV and at first launch updated to the newest WebOS version. My original issue is slow Wi-Fi speed on this device and after reading different forum threads here and on reddit looks like it's due to switched on "Listen mode" by default (Screen Share app). Just FYI on the same spot in a room I have 300 Mbps from my macbook device.
So my question is how can I switch this "Listen mode" off as with latest update of WebOS there is no such option in Screen Share app?
Related question/comment:
