21 hours ago, Martin Oxley said:
When will we be getting the 4.0 update so I can use Alexa please
That will all depend on what model of television you have, as older units will not be capable of running the updated software so will not receive an update.
    • By crct
    • By akhil7j
    • By Trung Hiếu Trần
      Specs: LG OLED 55C3
      Router speed: 250mbps
      System: webOS 2.3
      Any ideas on how to fix it?
    • By makem
      I have a  LG OLED55C14LB WebOS TV in the same room as my xubuntu desktop computer and router.
    • By Trevin
