webOS 3.3.4 - third party player or update for in-built player?
Hi there,
so far, the inbuilt media player was able to play a lot I threw at it, but it, but some videos just won't play. They are playing on every other platform and other videos with the same codecs involved also play, but there seem to be things (maybe a higher compression, bigger container data or something like this) that throws off the in-built player, so it just says "couldn't recognize media, want to continue with the next video?"
So I was looking for another media player on the LG app store but other than a few IPTV players and client-side streaming players (like Plex), I couldn't find any app that I could try playing those videos with (from an external hard drive which is plugged into the TV, that is). Basically, I'm looking for a VLC-like app that supports 4k and HDR. šŸ˜‰
Alternatively, there doesn't seem to be a way to update the in-built player, right? I assume it's included in the general TV update. Given that I'm up-to-date with this one, I assume this means that I can't to anything there.
Any help or suggestions are appreciated! :)
Ā
  • Like 2
    • By Jack1151
    • By mean2
    • By OliverRC
      Then I was prompted to update to the latest software version which I did and now often when I switch HDMI (running on 1) it picks up the device name, CEC works but I get ā€œNo Signalā€ā€¦ and then nothing.
      Just stays on ā€œNo Signalā€. It isĀ almost as if some HDMI handshake breaks and now the driver is in a broken state.
      Iā€™ve found that if I hard power off and power on the device sometimes works but I donā€™t want to do that every time especially since itā€™s hard to get to the power.
      Iā€™ve tried:
      Ā  The setup is the conventional AVR installation as shown in the attached file
      Ā
      Has anyone else experienced this?Ā
    • By Ajothen
      What have happen with screensaver?Ā
      It doesnt appear now and its dangerous for my Oled C3. It May cause burn in.Ā
