WiFi gets disconnected
By Ramesh Chand Vishwakarma
Regards,
MD/CEO
Noida, UP
+91 9910246766
By Guest
Things that I've tried:
factory resetting the tv leaving the tv unplugged to delete cache using google's DNS on the TV using a wired connection Having said so, I am so lost that I would be happy to try anything again.
By loafty
Tv connects to wifi and can stay connected for couple of days then I will switch tv on and internet (wifi) will be disconnected so go to connect up again and tv can't find any networks so turn off and unplug from power wait 5 to 10 minutes then plug all back in go to wifi settings might be lucky to find my network select and enter password and works again. Only thing is I got a different modem from internet provider and they have told me that the modem is working fine but I have never had an issue like this with tv before. Tv states wifi is turned off but I can't find anywhere that I can turn wifi on in the tv, does anyone know ?? Tried calling LG didn't get much help at all, I am 71 years old and just want my tv working the way it should so hope someone can help. Thanks
By Bhupendra
LG UN81006LB WiFi is so slow. I have tried with Wireless and Wired via a Ethernet on power adapter. I get on average 3Mbps whereas my laptop and smartphones can reach 100Mbps
What can I try please to resolve this speed issue
- 0 replies
- 1,792 views
- 1 answer
- 1,793 views
- 2,397 views
- 0 replies
- 10,434 views
Nishanth Noble
Hi!
The TV model number is UH850V and the firmware version is 05.30.30. I often get the WiFi disconnected automatically. I have tried manual mode too but it’s the same. Once disconnected it does not identify any WiFi signal. I have to switch off and switch on the Tv for it to identify a WiFi.
I would like to know if this can be fixed by software update or is this an hardware issue.
please help
