T & M Posted July 20, 2019 Posted July 20, 2019 I have tried every suggestion possible & still have no WiFi connection on my LG 60UJ6300 Has anyone come up with a solution for this problem? So frustrated Quote
0 Jay Joe Posted July 20, 2019 Posted July 20, 2019 I have no answer to this Wi-fi connection problem but I myself am having the same problem lately with my LG 49UH6030. It would always connect before easily. I have 5 other devices connected to the same Wi-fi, no problems. Quote
0 Jay Joe Posted July 20, 2019 Posted July 20, 2019 I just got it to work and connect to Wi-fi, make sure you have internet channels turned on, there should be an update, possible this is the cause. Quote
0 Glen Posted July 20, 2019 Posted July 20, 2019 6 hours ago, T & M said: I have tried every suggestion possible & still have no WiFi connection on my LG 60UJ6300 Has anyone come up with a solution for this problem? So frustrated Your router most likely provides a 2G and 5G frequencies/connections, you are probably trying to connect to 5G, so try connecting to 2G. Quote
0 hhibob Posted July 20, 2019 Posted July 20, 2019 Welcome to the club! So many of us have experienced failed wifi card - mine exactly one month after the warranty expired. Also, many of us are suffering from a message box that constantly pops up indicating that a network device has been disconnected - even when we have wifi turned off since the damn wifi cards don't work anyway. Wish I could give you some positive news on this, but short of having the wifi card replaced, not sure what other advice I can give you. Quote
0 MrBentFinger Posted January 14, 2020 Posted January 14, 2020 Here is the only fix I know of: Good Luck! Quote
-1 Ron Burnett Posted July 20, 2019 Posted July 20, 2019 I ended up buying a ROKU. I think it’s probably a better WiFi system than the one built into the TV. Just think of it as your replacement WiFi , that cost you $40. I gave up on the LG WiFi a month ago, and it’s such a relief to have reliable WiFi connected to my TV. Quote
T & M
6 answers to this question
