New update, magic remote not working
By OliverRC
By Ajothen
By Roy Brown
By Batman
SergioMx
I updated to lg webos 5.10.10 and the magic remote is working but when in Netflix, I point to the subtitles or audio language I press the button it doesn't select anything, but if I use the arrows and then I press the button it works.
