Embedded Subtitle Movie Problem
By PVD
By hollean
By AJO
By BozaB
I need help, I bought LG Oled 65 C41 LA tv two days ago, tv is working mostly fine, except when I watch LG installed streaming platforms ( Netflix and MAX tested ) tv freezes and after about 10 seconds it restarts. It does not have any pattern as far as I know, sometimes I can watch 20 mins, last two times after six minutes it crashed and restarted automatically. Can someone please help me, how can I resolve this issue? Did someone had sam problems already? Is my tv broken or I can do something to fix it?
By DeJaVu
Haloslam
Hi all,
I have a LG SK8100 series TV. I tried many times some m2ts and mkv movie with embedded subtitle but tv doesn't open the sub file. If I use external sub file everytink is ok but embedded TV didn't see anythink. How can I fix this problem? Do you have any solution for this problem?
