My leg keeps shutting off
By sbal
So sick of this stupid piece of crap TV. Every couple of days, the TV logs me out of my LG account and I can't use the IPTV channels.
Besides how incredibly and utterly stupid it is to require a f'in "account" to watch TV, when I go to log back in on the TV or the app (again I can't believe I need to download a f'in app to watch TV) it doesn't work. I need to change the location to Canada, reboot the TV, change the location back to US, reboot the TV, and then I can log in and am presented with the "terms and conditions" I need to accept (for the love of God why in the f'ing world do I need to accept terms and conditions to watch f'in television!?!?!?!). Then I click "Accept All" and everything works, for a few days, until it logs me out again for no reason and I need to go through the entire circus again
The TV is hard wired to Ethernet, so it's not a wifi issue. It's on a battery backup so it's not a power interruption issue. Anyone know how to fix this? This last time I went into the menu and the account and clicked the "Check Terms and Conditions" and there was a entry on the bottom with the green check mark so I clicked "Accept" on that one, I'm hoping that does it?
Needless to say there is no way I would ever consider for even a second buying another LG product, I will never give another dollar to a company that makes products so incredibly hostile to customers. but I spent a lot of $$ on this TV and I'm going to be stuck with it for a while so I am hoping this is fixable, despite how utterly ridiculous neededing to have an account or accept terms and conditions to use a device I bought and own
By Nicola123
By Flavio_S
By Nick Payne
Since the latest update to the Binge app on my LG G1 OLED, whenever I try to watch any program on Binge, about every ten minutes or so the app puts up a message on screen saying that it needs to restart to recover memory, and then restarts. And when I go back to the program, the app doesn't remember how much of the program has already been viewed, and starts again from the beginning - I have to fast forward through it to get to the correct point.
None of the other streaming apps I use on the TV - Netflix, Prime Video, Stan, Apple TV - have any such problem, and if I switch to viewing using Chromecast with Google TV, which has the Android Binge app installed on it, I can stream programs from Binge without any such problem.
