multiview Multiview feature & firestick 4k
By DW1
By Pranay Mokida
By Cody94549
By Željko2
I own a TV LG oled65c31la.aeu. I am interested in whether it is planned in the next firmware updates to return to multiview the
option of displaying two live channels (antenna dvt2), as it was earlier in webos 2.
Previously, a buffer was created in which terrestrial channels were saved, from where they were marked for display.
By MinoDc
Hi to all.
What do you think
- 884 views
- 7 answers
- 15,436 views
- 5 replies
- 14,457 views
- 3 replies
- 22,613 views
Tiffany Top
Hello all I have the
as anyone tried using their multi-view feature. I've just discovered that one side Amazon Firestick 4K and the other side just normal air broadcast. I have noticed that with the Amazon Firestick 4K will not let you watch anything on the opposite side you have to uncheck the firestick 4K then you can watch something on the other side. But what's the point because that's the purpose I want to watch both at the same time my firestick 4k and my over the air broadcasting channels. Does anyone have a solution to this problem greatly appreciate it thanks for your help in advance.
Note: This Feature work for me with the old Amazon Fire TV stick that is not a 4k.
