Hi... I have an Ai thinq 50uk6520psa. As soon as I bought it, I found that it was customer support over wifi, including Mp4 and MKV formats, but soon after the upgrade, the MKV files no longer appear in the list. Is it possible to resolve this issue, or undo an update?
2 hours ago, bcass1 said:
I would try to strip the .MKV from the title and try again.  My 65 inch Oled E8 TV does not supper MKV files and I take MKV off the title and they seem to play OK.
thank you very much!
    • By mahdi alborzi
      I need to update this TV
      Model : 55SJ850V-TA
      Serial number : 707CGKWMJ215
      ESN : LGTV20171=11001816919
      VSN : 1F580793
      Widevine: LGTV17CLGE002389488
    • By mahdialborzi
      از درگاه وای فای بروزرسانی نمی‌شود پس نساز به فایل برای بروزرسانی با فلش مموری کارت دارم.
      لطفا کمکم کن ید
    • By Jimout
      I am getting a "cannot download files" when I try and download a FirePro file.
      I was able to download before.
      Is there a way around or fix.
    • By Siva Shankar reddy
      Hi, We need know the information about  maximum file size limit for installable files , and the LG play store policies,  Need this info really help us on  application development process for LG ( web-OS ).  As per the Android play store we know, it allow's the applications based on the availability of internal Storage  on the specific device. Please Let Us help here to under Stand the LG Play Store behavior  for the application development process
    • By Kuriko
      Hello, I have a LG OLED C9 and a Synology Diskstation (Wifi). The LG shows in DLNA only very old files. I can't see new addes files/folders or I see deleted files. There is no "Refresh"-Button. Currently the DLNA for LG OLED C9 is unfortunately useless.
      I've seen in my research that that's been a problem for LG TVs for years. How can that be? Is there any workaround or trick to update DLNA?
