Hotstar app is not available in webos
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By tarakdave
    • By Nick Payne
    • By Bella Lee
    • Solution For That Pollution
    • By Alex
      Samsung has made fridges with touchscreens before. LG has made fridges with doors that turn transparent to show you the inside. This year at CES 2018, those two ideas are finally merging into one with LG’s new InstaView ThinQ smart refrigerator, which features a 29-inch touchscreen that becomes transparent if users knock on it twice.
      LG actually tried this two years ago, with a version called the Smart InstaView Door-in-Door that ran a full version of Windows 10, but it’s not clear that the company ever shipped the Windows version.
      Unfortunately, the only image that LG has shared showing the fridge is a low-resolution shot on its YouTube page banner, but it seems that you’ll be able to still use the screen while it’s translucent, allowing you to tag food directly in a vaguely augmented reality-esque move.
      Source:
